its not the motor it runs like a top the transmission is roaring when u drive i was wondering if it is normal or not this is my first golf cart or what might be causing the noise it is a 97 club car ds
i think it is in the transmisssion when i am going down a hill and put it in neutral it stops
so is the transmission hard to rebuild my axle and transmissionshare the same fluid
Back side of shifter, under seat, you can pull out and turn the cam to service mode. This will allow you to run the cart in neutral. It might help pinpoint the noise.
1st thing is check your fluid levels there are plugs on the pass sie i beleive...........if needed add some see what happens, i also wouldn,t drive the cart until i knew what iwas up against and then go from there.......................................
Does the fluid have any metalic stuff in it? Raise the cart and spin the wheels by hand in neutral. Then run it on the stand in gear. I would do some more pin pointing before ya tear into it. I'm just throwing possibles at ya.
i have changed the fluid i changed all the fluids as soon as i bought it and ever think looked ok but the axel trans fluid looked like it had a little water in it the fluid was a little white
