my cart wont move
mark468
Would like to say hi found this site by accident,but i do have an issue.I own a 1992 club car just bought last year and it wont move check the battery its charged it worked one day and not the next .Guy i bought it off said he just replaced the rpm limiter and it the second time in the 2 years he owned it,could i dare say be the prob again?any way to check ?also seems like it has a delay once you push the pedal down before it moves, any ideas?
Hi and welcome!!! First off is your solenoid engaging (motor turning over)? Or is it just a spark/fuel issue? If your solenoid is engaging and it takes a while for it to turn over it sounds like your starter belt is loose, which means when after a while of turning your motor over your belt heats up and finally catches.
mark468
Yes it turning you hear it but its delayed,oh also not sure if this helps seem like i hade to use the choke alot more than normal more like never to all of a sudden it had to be used
Ok first I would check the tension on the starter belt, next I would pull the plug and ground it to the motor to see if your getting spark, then last but not least pull your fuel line (the line from the pump to the carb) hit the gas and see if your line is spitting gas, if it is thats good. If all of these check out good.......... your on your own!!!!
No but Check them out Im sure one of them isnt working!!
