My Big Blocked Workhorse
ACEGOLFCARTGUY
Here is my 00 EZGO Workhorse. What a project it has been!! I've never had so much fun building a cart. If I have any say in it this will most definately be the one to keep.
There is still a lot of work to do before its finished but here are some pictures of it so far.
Grizzley
Looking at your cart makes me want to tear mine back down and do it again! Looking Awesome ACE! MORE PICS!
Gregg
ACEGOLFCARTGUY
Thanks guys!!
I need to get a bigger battery to power all the extra electronics. That thing came out of a 10hp lawn mower.
Any suggestions for a battery?
Grizzley
I run a marine deep cycle from Wally world. It helps if I have to use the winch while running the lights after dark.
Gregg
ACEGOLFCARTGUY
Today I'm going to be busy pulling the engine, cutting the motor mount plate out and welding in a new one. I thought I might be able to get by with how it is stock but the holes are about an inch off causing the belt to wear quickly. I'm not sure, but I think it may also be causing the motor to bog down in higher rpm's.
Wish me luck I'm goin in!
ACEGOLFCARTGUY
Thanks HRC!!
Engine and motor mount out
Boy thats a nice looking engine.
Old motor mount plate cut out
New one welded in. Tomorrow I'm going to clean the welds up, paint it and put that bad boy back in!!
ACEGOLFCARTGUY
I love my new Lincoln welder. I'm thinking about setting it up to use shielding gas but it does pretty good with flux cored wire.
