ezgotxtman
My 2006 Ezgo TXT, with the 295 problem child, and a pain in the back side when it comes to starting, running, etc. There are times it will start fine, run fine, and other times, start and when I shut it down, it will not start up... just the starter turning.
It's has a new fuel pump, new fuel filter, spark plugs, air filters, carb cleaned--5 times.
I've decided to remove the infamous 295 and move up to the top floor---a V-Twin engine.
This cart 'has not' been lifted in any form, only with 10" rims.. bigger tires.
Where is the best place to purchase this V-Twin and will it fit right into the frame space without any modifications? Is there a motor frame kit available? I can buy a 23 hp Honda V-Twin from a firm in Iowa--engine only.
