[email protected]
This has got to be a strange failure mode.
I was riding my 2000 TXT electric cart down the road normally. I applied the brakes in a moderate to heavy stop. When I went to start again the cart would not move.
Batteries were low on charge at the time so I started by recharging the batteries over night. The next day - still no movement.
I then jacked the rear end up I found that the wheels would move when pressing on the accelerator. However, if I held the wheel with my hand I could prevent it from spinning. Even when holding the stopped wheel I could still hear what sounded like mechanical motion within the transaxle.
Batteries may be close to end of life. I measue a no load voltage of 37.4 and a load voltage (with the rear end jacked up and the accelerator pedal pushed down) of 30.0.
Because of the timing of the failure, I tend to think I have a mechanical problem - maybe partially striped gearing in the transaxle, but part of me thinks an electrical problem might be the root cause and the timing of the failure was coincidental.
Any thoughts or direction?
