I got my new motor, but can't get the armature off. The motor casing came off real slick. I've tried heat at the spindle, tapping it but it is stuck tight. Is there a secret to this?? Rookie question again.
Sometimes they can be tough to get off. The armature usually slides of with the motor. Can you get in there to spray some penetrating oil on the shaft? Tap it with a rubber mallet, wiggle, and pull...
