Mixing and Mismatching Batteries
edsel60
i have 2 bad 6v batteries,have 2 rebuilt coming.can i use a 12v deep cycle with the 4 6v as a short term fix,no heavy use,just in and out of garage.would two 12v in parallel work better? would the 36v charger work with this.
JRay
Very short term, problem is it just wont charge right. Tried it converting a 36 volt to 48 , using a 12 volt battery.
JRay
Yes and the run time. You could damage the 6 volt batt. that are still good that you have in it, by over charging them by trying to charge the odd ball pack.
