I just got a Melex golf cart, looks good but needed batteries, replaced them ans stil doesn't run. I need a wiring diagram. Solenoid clicks but still no movement. Motor??? 36 volt, model 202, sn# 112108. any help or suggestions, thanks
Jack up the the rear of the golf cart and place on jackstands. Remove all wires from the motor. Put a jumper wire from an "A" terminal to an "S" terminal. Hook a 12 volt battery or 12 volt battery charger with 15+ amp range to the other "A" and "S" terminals that aren't jumped with the jumper. If the motor is good it will spin...
