Melex 152 Wiring
brucebb
HELP I'm having some problems. I went to drive my cart and the last battery in series started smoking and I heard a clicking. Any help?
Jeff10456
Well-Known Member
HELP I'm having some problems I went to drive my cart and the last battery in series started smoking and I heard a clicking. Any help?
need more details ... where exactly did the smoke come from? a terminal? or the whole battery vented smoke?
it sounds as tho it was a terminal ,,,, bad connection = intermittent power = equals things turning on and off = clicking
if smoke came out of the vents or the terminal is no longer usable you need a new battery
mean while one cable end at a time
remove and clean the end and the terminal on each battery, then tighten securely
battery mfg's website can give you a torque value
in general as tight as you dare with out twisting the terminal out of the battery
once you have all battery cables cleaned, and tight use a terminal sealant or heavy grease to seal acid and air out of the terminal connection
you want to do this, unless you like buying batteries before they are used up
