Melex 112 rewire problems...Help!!!
wormsworld76
Hey guys,
I have a Melex 112 around a 75 model and I am trying to rewire it. The keyswitch wasnt hooked up nor were other things and when I would put it in forward or reverse it would kinda jump telling me that there is power to it even when the cart isnt moving. So I decided to rewire it according to a diagram I found for an ezgo which had the same wiring as a melex 112. after I got everything done I hooked the batteries up and noticed I didnt have any power. I put the cart in forward....then reverse and when I did I heard some arcing. I switched it back to forward and it arced again causing a fire on the F/R assembly. after taking the assembly off I noticed the arcing was between the concats on the assembly. I want to make sure that my cart and everything is wired correctly and I need a diagram that shows everything from keyswitch to microswitches even all connections of solenoid .....everything. the diagrams from "vintgage golf carts" don't show the small components like keyswitch and microswitches. I found one from the "image shack" for an ezgo with the same wiring but with the keyswitch and microswitches. If anyone has any ideas please help me figure this out.
thanks,
worm
