Low battery indicator
lee miners
I have recently purchased a second hand 1995 Club Car. I have a possible two problems. The reverse warning is not working but does when I operate the middle micro switch at the charger socket. Do I replace the switch or can I adjust it? Secondly, how/when does the battery warning light come on and how do I test it? I have not seen it come on during 4 recent 18 hole rounds.
What are member views on auto battery filling systems?
Petey
You can adjust the micro switch but be very careful bending the arm. As far as the low battery light not coming on, I usually have to run my cart more than 36 holes before my light comes on so I would not worry too much about that unless you are noticing severe power loss after 18 holes. My opinion on auto battery filling systems, that in my case, is a waste of money. I check my batteries on a regular basis and have not found significant fluid loss. If I had an auto system I would still be checking on a regular basis because I just don't trust auto systems.
