DickB
I have what I believe to be an early 80s EZGO. I have an 86-1/2 - 87 owners/service manual that matches my buggy, except for the rear end. The manual shows a split gearcase. Mine is one piece with a bottom differential cover. I have seen references to a Dana rear end and a T bone rear end. I am looking for a service manual to match my gearcase. The ring gear has some corrosion on about a dozen teeth. It works, but makes a cyclic grinding noise when those teeth come around. I have a line on a used rear end, but the splines are worn on the drive shaft and I would need to swap parts. Prefer not to do it blind.
