Looking for a wiring diagram Melex 745 1988
aretakis
I have a Melex model 745 that was made in 11/14/1988. Of course I was told that this is an EZ GO copy. What I cannot find is a wiring diagram that corresponds to my cart for the same year of an EZ GO.
I am in the process of cleaning up the burnt and cracked wiring and moved on to some of the control wiring. The wires I cut ended up not being the wires i thought they were when I went to connect to the new wires. i removed two blue wires from the post of the solenoid with the POSITIVE battery wire connected to it. I removed what I thought was the same two blue wires on the F/R contactors. It appears that two of those blue wires were from the key switch.
Now I need some help... The more I look the more it seems like someone hasn't wired this correctly but I am new to wiring carts.
Cart was working before I touched it today. I attached pictures of the controller, solenoid, F/R, ect. Any help would be appreciated. Thanks.
aretakis
Contactor isn't pulling in on the Pot box. Previously, when the key was switched on the contactor pulled in and heard the "click". only difference i see is there is no WA device for when the cart is in reverse. Need any suggestions or point me to the correct thread if possible. Thanks.
aretakis
Nevermind! had the wire from the key switch on the wrong terminal on the F/R module. It runs again. Notes on the wiring diagram: All the same put the pot box appear to be different. Might just be my understanding of the drawing and symbols. Thanks for the help!!
