I have converted my 2013 EZGO RXV to a LiTime 48V 60Ah LiFePO4 lithium battery, and it is working real good. The battery has a BMS that constantly checks the status of the battery and checks for dangerous situations and shuts-off when it detects such problems. I am now trying to install the battery monitor that is recommended by LiTime for it. It uses a shunt. The monitor is installed but is not showing valid information, and it flashes constantly when turned on. The install instructions shows 6 parameters that are stored, but only says to enter the "Ah Capacity" which is 060.0 Ah, the "resting voltage" value when fully charged which was 56.8 V, and the "Zero Capacity" voltage value which I entered 000.0 because I didn't know what to enter. The other three parameters that are stored are "PowOff" voltage, the "Alarm Ah" Amp hours to warn when the charge is getting somewhat low, and the "Atten %" which is the battery attenuation ratio. But the instructions do not say anything about loading these values and what the values might be. Presumably if the right values are entered into the monitor, it will display valid battery status information.
The information the LCD is supposed to display is: (1) current Capacity Percentage; (2) Present Capacity in Ahs; (3) Charge/Discharge status (arrows up/down; (4) Remaining Charge/Discharge Time in hours&minutes; (5) Present Voltage; (6) Present Current in amps + or -; (7) Present Power Consumption in Kws.
The Capacity Percentage has always stayed at 100% thru 3 rounds of golf. The Present Capacity in Ahs has always stayed at 60 Ah thru 3 rounds of golf. The Charge/Discharge arrows are showing charging. The Remaining Charge/Discharge Time has always stayed at 00:00 hr/mn. Present voltage has declined from 54.x to 50.x.
The Present Current keeps changing rapidly. The Present Power Consumption keeps changing rapidly.
Can anyone help with what the 6 parameter values loaded in the monitor should be? The first 2 I believe are correct. I think the Zero Capacity Voltage needs to be a value other than 000.0V. The battery shut down when the voltage was above 48 V. I am guessing the PowOff voltage should be set at about 48.0 V. The Alarm parameter default is 40.0 Ah now, but should probably be at about 20.0. I have no idea what the Battery Attenuation ratio should be.
Can anyone help me with getting my battery monitor working properly?
