late 80's ezgo 2 stroke
outlawpat
My cart runs fine, but the last two times I used it I noticed that at 75% throttle or greater it feels like a belt or clutch is slipping as it feels like the cart is lurching or almost like the rear axle is loose. Very hard to explain, but it almost feels like the rear tire is wobbling.....but I am sure it is just due to the belt engaging/reengaging or some sort of slipping.
Is there a way to adjust the belt tension?
outlawpat
Drive belt seems new.....it is the type with the grooves that run perpendiculare to the drive pully. I would have expected to see a flat belt.
Is this the correct belt? What are the symptons of a failing clutch?
