Well I finally had to register here……. Looking for guidance
2001 Club Car DS cart. Converted from resistor coils to Alltrax SR4800, A1, On board Lester charger and new voltage reducer.
Hooked everything up and worked perfect for about 2 weeks. After troubleshooting, it was the electronic pedal. No fuse blown, voltage still passed on green wire to Alltrax, no voltage passed to micro switch on FR switch. Replaced pedal and moved pedal off a ground bus bar to Alltrax B-.
Well three weeks later, same thing. Ran fine, parked in garage and hooked to charger. Went back a few hours later and it was dead.
Same tests run, pedal bad again. EMF from being shut down?
Diode and resistor on main coil ohm out appropriately. Any suggestions on something else to check for? Or any isolation circuit I could add to the pedal to protect it? I am at a loss and pedals are expensive.
Thanks in advance
Thanks in advance
