ACEGOLFCARTGUY
Would some very smart person out there be able to help me with wiring my 27hp Kawasaki engine?
The engine didn't come with a key switch, but I have that all figured out with a universal key switch and the engine wiring diagram.
Here's where I need help. How do you wire accessories like lights?
Do you run a wire from the pos battery to the fuse block and then run everything off of that fuse block? So for example, there are 3 lights for the guages(temp, volt and oil pressure). How do you go about wiring them from the block to a switch?
Also, I have the engine set up with an electric fan for the radiator. How do I run that through a relay to reduce the load on the key switch?
Thank you
Thank you
