Just Found a 1963 Harley Davidson Gas Golf Cart
Dishmans2
I just found a 1963 Harley Davidson gas golf cart. It had the top the old man said but not sure where it is tons of stuff on this property probably can't find it anyways. But looks complete and from what I found online from data plate it's super early gas model with the steering wheel not the chrome bar. Any advise on engine to see if it will run. Also I couldn't find other 63s like this for sale to see if I should keep it and use it around the ranch or just let the next guy mess with it. Thanks Bryce
Grab the clutch and see if it turns to see if the motor is locked up.
Put a battery in it see if it cranks.
I'm sure at a minimum the carb and gas tank will need to be cleaned to get it running.
Sturgeon
I picked up a 63 HD tiller model. Runs but needs work. Still looking for a carburetor. Anyone know if a 67 carburetor will bolt up to it?
I think it will bolt on but you'll need to modify the throttle and choke cables. I'm not 100% sure so you may want to wait to see if someone else on the forum knows. Also you can get try contacting vintagegolfcartparts.com and they would know for sure.
