JodyW
I recently upgraded my batteries from lead acid to lithium. With the kit I purchased there is a breaking resistor which, after some research, I think I understand the function. My problem is I cannot seem to find any videos/articles that talk (in easy to understand English) about where to connect the two cables (look like positive and negative). I called the place I bought the batteries and they admitted they were not sure and suggested just connect to battery terminals. After closer observation I realize there is a terminal made specifically for the red cable (has a smaller than normal ring terminal) so I feel good that it is connected correctly. But the black cable (also ring terminal that is same size as normal battery terminal). I already had my limit of terminals (based on available post space) on the negative battery post, so I was told to connect it to the frame for ground.
I found one video online that was not specifically for a golf cart, and it was almost impossible to understand their English (Asian created the video. In the video they showed connections that looks more like it was connected to the controller. I want to make sure what the best method is.
Does anyone have any experience installing one of these? Battery is a RoyPow S1105P and the resistor does not have any manufacturer label.
