I have 2005 Ezgo PDS that will not move. I have power to the Alltrax controller in both forward and reverse. The solenoid clicks when you switch to forward or reverse but not when the accelerator is depressed. When you push on the gas pedal I get nothing. Is there any way to verify that the micro switch or the Inductive Throttle Sensor ( ITS ) is the problem before I spend the money to replace them. Is there anything else I should be checking?
