Ignition switch
dougmcp
Push the center pins through the plastic rivets and pop the plate out. Use screws to remount the plate.
If you don't want to use screws you can remove the top of the cup holder and usually find the plastic pins Doug mentioned, they fall inside the cup holder when you push them out. The pins can be reused.
