I Purchased a Curtis 1313-3231 Scan Tool to Help Diagnose Problems
Papas 73Dart
I purchased a Curtis 1313-3231 scan tool to help diagnose problems. I would like to be able reset speeds but it wont let me. Is there any way to upgrade either with program on an SD card or by interface on line with my computer?? too many carts at our resort are set to go way too fast ! I use the scanner on a regular basis to help diagnose and fix problems so if there is a cost factor I would be willing to pay a reasonable fee !
What does it tell you when you try to change speed codes you can only do 1 2 and 3 you cannot do code 4
Papas 73Dart
In a lot of cases they need to be slowed down. Our resort has a speed limit of 15kph/8mph and a few customers hav asked if I can cut back their speed. Most factory settings for carts is in the 10-14kph range . Nobody really objects if your Cart can do 20 but I have personally seen some doing 25 + and with all the kids at the resort thats just dangerous!
My code 5 can be programmed for any speed between 1 and 23 on stock carts.
but speed code 1 or 2 would be close enough your programmer should be able to set speed
