bobsusancart
Found the fill hole, rubber plug on driver side of differential, about 1 inch in dia and 2 inches above the axle, cart guy local says fill til it over flows. I think that may be too much oil because there's a bolt on top of the axle on the passenger side that drips oil so I think you remove that bolt and fill til that overflows. I think mine is missing the gasket (small fiber washer?) on the bolt and that explains the drip, or maybe I'm the drip...
