HOW BIG CAN I GO!!!
Kainalu
This has probably been asked before but how tall of tire will fit under club car 05ds (gas)with a 3" Z lift. I have found a set of 22x10 on offsets at a great price but dont know if they will fit. If the back will be a problem I can fix that its the front thats the question although there is more clearance up front since the z lift pushed the axle forward 1 and 1/2". Im sure there are some of you who have stuffed these tires before. The plan is to machine the clutch and add the powerspring also wondering if the performance will still be thereafter those mods. Asit is now it pulls me 200lbs and my buddy 300lbs all over our hunting club no problem long as tose stock tires dont start spinning.
dirtysouth
Should fit fine.
dirtysouth
Minimal difference, only hills that the cart could barely climb on stock tires will be a concern.
Kainalu
The only hills it hasnt climbed now are the ones that I loose traction on. Then Im doing the golf cart shuffle from drivers side to pass. side to gain traction.
jterango
you will have a rubbing issue with 22x10's. get kenda klaws 20x 11's problem solved. thay are tight. moto sport.com for $65.00 each.
