My 98 western won't turn off if the lever is in the rev. pos., this is with all the wires removed from the switch, though it buzzes it won't activate the motor. when checking the voltage from the white wire on the micro switch i get 18 volts and this is with all wires removed from the switch. I removed the 5
pin plug on the controller to see if that stopped the buzzing it didn't. I know nothing about 12 wiring as DOUGMCP can attest to, right Doug. I need help bad. Thanks, Kangolfer
