hooking up a LED battery meter
mikefla31
Hello I just got a battery meter in the mail today and it doesnt come with very good instruction.. I only have a AC volt meter my question is my cart is 36 volt and has headlights and tail lights are most of them hooked up 36 volt? if not i guess i need to go buy myself a dc meter to find my 36 volt connection on my batteries. thanks
I believe it would hook to the front left negative and front right positive battery terminals. Batteries 1 and 6
dougmcp
Go buy a meter, with an electric cart you are lost without one.
How many connections on you LED state of charge meter?
Where did you get it?
Can you post the site info where it came from?
Pimp Daddy
Mike... Not trying to sound like a smart azz...
Hook it up on the + and the - on the battery pack...
Where the big cables come off going to the controller...Just sayin'....
mikefla31
ok i got a meter today and figured it out tks guys.. now i got a bigger problem though.. i put my 6 inch lift and tires and wheels on today and it looks like it made either a weak hub or axle show up.. something is slipping...
dougmcp
Check the torque on the rear axle castle nuts to at least 90 lbs.
Check that your brakes aren't locked up from lifting and tight cables.
