help
cajunboy
I noticed my cart slowing after short time in use I replaced the batteries do to the cart being an 04 model (J2504) I just bought 1 yr ago. can anyone give direction to fine a potential wire or electronic problem.
ftfixer
how long ago was it that you replaced the batteries and are you sure that you are getting a full charge.you may need to check the voltage on each battery and also check your full voltage while cart is running.
cajunboy
replaced the batteries are 5 days ago, the voltes on the batteries are (individuel 6.2 and total cell is 38.5) when I checked the volts while running I am reading 34 volts at max output. I noticed the difference in the speed after I came to a stop and started moving again?
ftfixer
does the cart actualy slow down realy slow just after starting or does it seem to have a burst of speed and then sort of level out.
6.2 volts is a little low for fully charged new batteries. It will take 10-15 charge cycles before the new batteries will be working at full performance...
