That's the reed switch wire. It should connect to a micro switch on the forward and reverse switch (MS2)... There will be a double terminal on the micro switch with a red wire attached to to one of the terminals. The reed switch plugs onto the other open terminal...
Here's a link to the wiring diagram you need...
