Hello All,
I am new to the forum and need some help...
A little about me, I have been messing around with golf carts for about fifteen years or so and doing most fab work myself. I have lifted a few and have done a engine swap on my 95' Medalist.
So I am ready to pull that engine that I put in last News Years Day (9 hp stock motor). I built a Copy of my 95' that I turned into a cart trailer. The problem is the 9 hp just does not have enough power to climb the hills pulling the trailer with four adults and party supplies.
So here is the Skinny........
I purchased a Honda 24 hp V-Twin GX 670,(used $550) I know I can get a new engine cradle from CPP.
But what does everyone recommend when it comes to a pipe and clutch??? Shaft is 1 1/8" on the Honda, so could I use the stock clutch???
Wiring.........
The motor has a starter so that kind of a no brainer.
However I have Two Gray Wires by the starter.
One Black Wire with Red Stripe
One Black Wire with Yellow Stripe
I do pretty good at reading schematics, however pictures and a hand drawing are worth a million words. If someone knows how to integrate some of the existing electronics/wiring to the Honda that would be great.
I know that the gas pedal start will go away which if fine.
The guy I purchased from had a few of theses and one out of his wife's cart but his wiring was a hack job and the pictures I took do not help. He did not do the conversion.
Any help you guys can give is greatly appreciated.
Thanks!!!!
James "Poolman" Henry
Wiring.........
Thanks!!!!
