My 2013 Yamaha Drive with EFI hesitates to start when I press the gas pedal all the way down. Sometimes I hear a high pitch hum and it does not do it all the time. Is there a problem? Any ideas?
Does it hesitate every time it starts or only when you hear the hum? I'd check the starter/generator belt to make sure it's tight. You should also load test the battery and check the battery cable connections.
Welcome to the forum.
Thanks much. It does not always hesitate and it does it without making the high pitched hum. I did check the cables to make sure they are tight. I don't have the equipment to load test the battery so I will have to take it some place for that. I have not checked the S/G belt but I will do that today.
Thanks again for the reply.
I tightened it up as much as I can. Still have the same result. I had the battery load checked and it is sat. It may be a little better but still from time to time I can push the accelerator down and maybe count to three before it starts to go. Maybe I should just take it into the local Yamaha shop and have them run checks.
Thanks for everyone's support.
