Hello all, I am glad I found this site. I will give some history on the situation and this cart.
This cart is my 68 year old grandfathers. He has had it for probably 10 years or so. He had problems of it running rough last summer so he took it to a small engine school teacher who had worked on it before. This teacher proceeded to keep it for 9 months just to change the points out. (I think they are called points) Regardless he got free storage over winter but when the teacher installed the points he had cracked the case or something similiar. The teacher couldn't get it right so they took it to the local ezgo repair shop. They put a new point that wasn't cracked and sent grandpa on his way. Grandpa took it out and it didn't run good at all. Grandpa took it back to the shop where as they said "worked on it for a week, removed the motor twice and don't know where to start" and gave it back to him free of charge.
The cart is a 1979 Ez-go. The tag on the passenger side reads 79GO and I77346. It has a 2 cycle EC25DS robin engine it. The displacement is 244cc The Motor # is 115810.
The motor runs like it is missing badly and doesn't accelerate. The ezgo shop said that the fuel supply checked out alright amd think it is something in the motor but I think I should start from scratch to make sure I don't miss anything.
Should I run a compression test on it first to make sure internals are ok? What should compression be?
I have read where people are having clogged mufflers, is this a common issue that I should check out on this particular model?
If compression is good then it must either be ignition or carb related correct?
Sorry about the long first post. I have included some pictures, I don't even know what the model type is of this cart. Any and all help will be much appreciated.
Thanks,
Thanks,
