Heater for EZGO RXV
Jeff Frye
Hey guys. I have a 2015 EZGO RXV with a tray mounted above the cupholders. Have any of you figured out a way to use one of the portable propane heaters? The tray prevents the use of a heater using one of the cup sleeves because the front cup holders are too small and the height of the two heaters I have tried eliminates the use of the two back ones. There is a 1" square tubing that runs underneath the tray that I feel something could be fabricated and attached to but wanted to see if something else is available before I go that route. Thanks!
Jeff Frye
I have decided to have a bracket fabricated. I know there will be interest in how it turns out because there are several guys where I play that are having the same issue. If there is any interest I will post some pictures when it is done.
