Headlights Work Tail Lights Do Not Work
Dennis Mast
I currently have a problem with the lights on my golf cart. Turn signals work but headlights and tail lights do not work, brake lights as well. The odd thing is I just purchased this LED light kit and hooked everything up and it worked just fine. I got on it the other night and no lights. I have not to check with a meter but I did check the fuses and all good.
Patrick L
If you just installed these lights, then, it kinda sorta sounds like a connection may have come loose. A test light should help.
