Headlight Dimmer Switch Club Car 2023
snowmanhat
Hi, new to the forum - just bought a 2023 Club Car Onward and the head lights are way too bright (cars are flashing me their bright and other cart are irritated when I pass them. Dealer said there is no low beam / high beam switch and no way to dim from factory. I saw dimmer switched on Amazon and was thinking about adding but can not find a wiring schematic on line. Has anyone had this issue before and what is the best solution. Thank you for your help.
What you would need to dim LED lights if LED would be a pulse width modulator or pwm basically a little module very similar to a controller that works on 48 volts DC
Something like this might work I think it's under $20 on Amazon
