Sorry but I'm not an expert and electronics scares and confuses me so bear with me as I know I sound like a bumbling idiot.
So I bought a cheap used EZGO TXT that has been heavily modified I guess. I've been tinkering with a few things and was trying to figure out how it's wired. As I dug around, I found many things that I just can't explain what the hell is going on!
First, there appears to be an entire wiring harness that is mostly unused... It's there, just only one "branch" is being used, not sure what the wires are for. There is another harness running on the opposite side straight to the controller that is actually used.
Second, somebody removed the 36v / 12v converter and I don't know why anybody would. The stereo system is wired straight to the batteries so it has issues with cutting off when voltage drops below 12v or at least that's what I believe is happening. I would like to correct this with the 36v converter. The 12v charging port is completely disconnected. I would like to wire that back in.
There is a fuse block that powers the horn, front lights and what I assume is the rear lights. I cant confirm the rear lights, have to order new bulbs. I don't understand how where or how the horn and rear lights complete the circuit. The green wire runs straight to the battery, so I guess the horn and rear lights' black wire ties back into the negative terminal somewhere?
The amp meter always reads full charge. It's ran across the entire 36v system and directly wired into it. Is this normal? I would like to get the amp meter to work so I can see the battery charge.
