HARLEY CART CART
LUGNUT43
I HAVE A 1984 4 WHEEL HD CART GAS...MY SWITCH KEY LOCKED UP...HOW CAN YOU WIRE AROUND IT TO USE A TOGGLE SWITCH...IF SO SHOW ME A DIAGRAM OR WALK ME THRU IT...I CANT SEEM TO FIGURE IT OUT...AND I KNOW IT ISNT THAT HARD
Bass Hole
There should be 3 wires on the original switch. You need to use a 3 position toggle switch for forward off and reverse. Wire it the same way as the original key switch for forward and reverse.
LUGNUT43
BUT I TRIED THE THREE WAY SWITCH BUT NOTHING.......AND NOW I HAVE OTHER PROBLEMS....IT JUST QUIT RUNNING...I HAVE A NEW COIL POINTS CONDESER.PLUG.AND PLUD WIRE..BUT I CANT FIRE TO THE PLUG..OR COIL OR ANTHING..IT TURNS OVER JUST NO FIRE....NOW I WIRE IT BACK UP THE OLD WAY WITH THE SWITCH STILL STUCK IN REVERSE..I CHANGED THE WIRE ON THE SWITCH TO RUN FORWARD AND IT RAN ALL NIGHT THEN JUST QUIT.....SO CAN YOU HELP
LUGNUT43
i got a wiring diagram offline...but i still cant tell how to wire around that switch.....its the kind where forward and reverse are both in the key switch..
