I have a 75 Harley 3 wheel cart with the 250CC 2 cycle engine. There is a rubbing sound when running, it appears to be a bad bearing. I have all of the parts to rebuild it, but when tearing it down could not determine how to remove the flywheel so that i could split the case for crank removal. I am hoping someone has done this in the past and wouldn't mind sharing how the flywheel is attached, and the easiest way to remove it.
