half speed forward, only 18v
TSon3
Hey All, New to forum, but I like it..........Have a question:
Have '95ish 36v Ez Go that runs half speed in forward. Only half volts to motor with pedal all the way down. The ITS checks out good with meter. Swapped controllers with another one, same problem. Swapped solenoids, same problem. It has a speed sensor on motor, could this be problem? If so, how do I check it?
OlBoy
Yes it can be the speed sensor. Someone just posted with the same problem and it was the speed sensor.
