Greased Front End, Still Hard To Steer!
carshowdave
I have a stock plane jane 2002 Club Car Golf Cart. Have had it two year's. Noticed it was hard to steer when I took it out this year also pulls to the left when you are moving. Greased front end but no better.Any idea's on what to look for and how to fix it? Dave!!!
If the air pressure is good and the cart is pulling to the left you must have a front end alignment issue or a bad tire.
DWscott
Simple basic tools are all that will be needed for alignment corrections. One thing that is handy when doing alingment is a carpenters square. Check your steering gear assembly for lubricant as I have found some newer carts with NO GREASE IN THEM??? Cut the plastic ties on each bellows and look for lub inside rack and pinion assembly. Then replace with simple wire ties after checking.
carshowdave
Hi DW, Those are all excellent idea's. Going to use them this weekend, I will let you know what I find! Car Show Dave!!
