governor adjustment
Ironyetty
Mine has done the same thing. It is black smoke coming from mine. The engine compression is 150psi and seems to have plenty of power. What should the compression be?
Thanks in advance,
ironyetty
150 is good on the compression. You may have a little dirt in the carb. Make sure the air cleaner box is sealed tight at both connections and the lid is sealed good.
Ironyetty
it turns out it is more like white smoke. i am positive it is oil burning. i just rebuilt the motor am getting 160psi and made sure the air box is sealed. do the g16s have a problem with the heads cracking? help!
Ironyetty
Ironyetty
Compression is good. Make sure it's not over full on oil. If the oil level is ok I'd say your over reving the engine.
