HotRodCarts submitted a new resource:
Motor Testing Series and SEPEX - Electric Golf Cart Motor Testing Series and SEPEX
Read more about this resource...
SERIES wound motor test:
Jack the rear tires of the ground and put the cart on jack stands...
Remove the main positive and negative cables form the battery pack...
Spray the 4 studs on the motor with a little penetrating oil...
Mark the cables then remove all four cables from the motor (use a wrench to hold the jam nuts)...
Put a jumper wire from a "A" terminal to an "S" terminal. (Example: A1 to S1)...
Then hook a 12 volt battery or 12 volt battery charger in the 15+ amp range to the...
