My Club Car golf cart 2008.5+ has a pressure sensitive brake lights switch mounted behind the rubber brake pad and the metal brake pedal. Two wire open/closed switch. Any idea where I can find a replacement?
Second question. Club Car Precedent, 2006 model. The brakes are activated by a magnetic switch that is attached to the brake pedal group. The switch has a groove in it and when the brake pedal is pressed a piece of metal slides into the groove and actuates the switch. The switch is labeled ITW Switches,
Model:CMT-1008. Any idea where I can find this switch? If not, the wire has three wires going into it. One is a fused red lead. One is brown and the other is black/white. Does anyone have a schematic or info on how this switch is supposed to work. Is it a time delay switch?
