goes and stops?
Larry118
Hi,,I bought a mid 80's ezgo marathon...has resistor coils in back...my problem is once you hit the throtle it goes then if you let go and hit it again it doesnt always go again...it does it in forward and reverse....do I need a new speed controller?.Thanks
It could be several things causing the problem. Make sure all your cable connections are clean and tight. Check connections at the forward and reverse switch. Does the solenoid click when the cart won't move?
Larry118
just took the seat off and listened....solenoid clicks when it goes but no click when it doesnt go......bad solenoid?
I would double check ALL your cable connections first. Make sure no cables are loose or look like they've been hot at the forward and reverse switch. It could also be the pot box. What do you do to get the cart to move again after it stops?
