GAS IN CRANKCASE
Gaspumpguy
I was wondering if anyone can shed some light on this, I have a 2000 Club Car Turf II. I am getting gas in the oil, I have replaced the fuel pump (twice) Installed a new carb, replaced all the fuel lines, filters, gas cap. even disconnected the fuel pump and installed a small electric pulse pump, No difference. I can change the oil & filter and within a couple days the oil is starting to get milky and smells like fuel, If I continue to run the cart it will delute and thin the oil enough to make the oil light come on. I am at a loss!!!
I'd pull the carb and check the float and the needle and seat. I've seen new golf cart carburetors with the float set wrong and or dirt in the float bowl
shadowman
did you check that hose coming uot the front of engine down below? if that gets plugged it might send oil into the C.C...........................................................
Gaspumpguy
I checked that and replaced it along with the other hoses, I also checked the float in the new carb.. I finally took it to the local golf cart dealer where I purchased it, he kept it 3 days. Said he has never seen one do that, he didn't have an answer for me..
shadowman
i,ll bet if he took the fuel pump apart he would find something wrong with one or both of the diaframs.....................................................
ford
i had this happen to my ez-go and it was the fuel pump. try that i bet that will fix your problem
Gaspumpguy
I have purchased two new Club Car pumps, same thing happend, then I installed a small elect pump,, same thing.. two carbs, three pumps, trip to the dealer same problem...thanks for the input guys...
