W. Limp-Lump
Yamaha G5 to G9 conversion New to the gas cart World converting a g5 into a g9 with g9 wire harness and components but using the g5 j38 motor the motor turns over but when the voltage regulator /rectifier is plugged in it won't turn over and blows the 10 amp fuse although the regulatory is new is it possible its defective or the wrong regulator the starter/generator starter solenoid, and key switch the CDI box are new as well with a used g9 harness can anyone help i surly would appreciate it thank you
