G22E question
tcart05
I have a 2005 G22E, 48V Yamaha Cart and it will not move when I step on the accelerator. If I flip the tow switch, I can hear a click. I then step on the accelerator, it will move for a couple of inches and then cut off. It has done this while driving, but it has always started running after a very brief delay. Now, it does not move. Any suggestions?
BadToTheBone
Moderator
flip the tow switch to tow then jump the to large posts on the solenoid. flip the switch back to run and try it. if the cart runs replace the solenoid.
silverdude
sounds like you tps sensor is bad or out of alighnment, pull up the floor board panel look under the accel pedal check the switch,
