G16 where is my oil going to ?
yama97
My Oil Lite Came on and checked oil and it is almost gone ! This has happened at least 2 times before,I fiil it to level and no problem for weeks ,I do check it every day as it is used that much! The cart does smoke a little but do not see where it would suck up that much in a short period of time,the engine is clean and no signs of a leak
Larryr
pro1motors
are you over filling it??? i had this problem..i just added oil..and messed up my motor... they say you change your oil.. and add 1 quart..that is it...if you over fill it..it will mess up the rings..and smoke...sorry.
