G16 trans oil
99yami
I was just wondering how often you should change the oil in the transmission? I have had this cart for several years and have only changed the oil and replaced the carb. I do not have a manual. Also, what kind of fluid to use? Thanks!
djlan99
These need the engine oil changed once a year ( at golf course use ) or private use.
I have never changed rear diff oil in any carts only checked level.
djlan99
I would use 90w gear lube. Make sure you find the bolt for the correct oil level.
I don`t remember if these had a drain plug or not I would only fill them when I had them apart.
All shafts have ball bearings nothing special here.
