g16 starter runs on
vmax28673
noob to golf carts here. not new to fixing cars, bikes, jetskis, etc.
i have a 99 g16. two issues.
the starter runs on after the pedal is released and the cart is stopped. this happened when i tested the pedal switch by unplugging it while it ran on. could this be the engine stop relay at fault?
also what should voltage read at full throttle?
thanks in advance for the good advice.
phil
kogieblack
:unplugged the pedal switch the engine keeps on running. This could be a faulty solenoid (others call it relay). If you tap the solenoid and the engine stops running, then it is a solenoid problem. Borrow or buy a replacement.
