G14 no spark
BobSekera
I need to knowwhat the Pickup coil resistance is supose to be on a G14. I am getting 326 right now. Is that within limits? I have checked all previous ignition system item up to this and they are within limits. I still have no spark.
The Yamaha ignition systems can be tricky to troubleshoot. Do you have 12 volts going to the coil? Is the ground from the engine to the frame good? I'm pretty sure the pickup coil range is from 325k - 350k ohms.
BobSekera
Sorry, the ground from the battery goes directly to the starter/generator and I just replaced the connector on the battery end. I'm getting a good reading from the engine to the battery. Should the engine be grounded to the frame of the cart?
You should have a ground strap form the engine to the frame also.
Here's a Yamaha G14 wiring diagram.
